hi ... i 'm working on a project in which i need to get the data processed by the mbed and save it on my pc ... do anyone have any idea about how to make this happen???
thank you in advance.
How much data and how fast do you need to get it to the PC? Is it something that you could write out to the 2MB LocalFileSystem and then copy off later or do you need the data in real time on the PC? If so, how much data do you need to send per second?
the application i'm on now needs real time streaming of processed data from the mbed to the pc with a rate of 10Mhz (i mean a signal every 10 e-7 seconds)
The USB serial link maxes out at 921600 baud so you will need another way to transfer data to the PC
If you are talking about data at 10 MHz is this a single bit or multiple ?
Ethernet might just do it.
What are you processing at 10MHz... Maybe the mbed isn't the appropriate solution...?
Important Information for this Arm website
This site uses cookies to store information on your computer.
By continuing to use our site, you consent to our cookies.
If you are not happy with the use of these cookies, please review our
Cookie Policy
to learn how they can be disabled.
By disabling cookies, some features of the site will not work.
Access Warning
You do not have the correct permissions to perform this operation.
