saving data in pc
23 Jul 2011
hi ... i 'm working on a project in which i need to get the data processed by the mbed and save it on my pc ... do anyone have any idea about how to make this happen???
thank you in advance.
23 Jul 2011
How much data and how fast do you need to get it to the PC? Is it something that you could write out to the 2MB LocalFileSystem and then copy off later or do you need the data in real time on the PC? If so, how much data do you need to send per second?
23 Jul 2011
the application i'm on now needs real time streaming of processed data from the mbed to the pc with a rate of 10Mhz (i mean a signal every 10 e-7 seconds)
23 Jul 2011
The USB serial link maxes out at 921600 baud so you will need another way to transfer data to the PC If you are talking about data at 10 MHz is this a single bit or multiple ? Ethernet might just do it.
23 Jul 2011
What are you processing at 10MHz... Maybe the mbed isn't the appropriate solution...?
