It's probably easiest just to use a timer to measure the time taken by a call to the ADC library.
But if you are really curious, it is possible to adapt some code from this adc library to find out the actual settings of the ADC clock.
Here is a relevant excerpt from adc.cpp:
ADC::ADC(int sample_rate, int cclk_div)
int i, adc_clk_freq, pclk, clock_div, max_div=1;
//Work out CCLK
adc_clk_freq=CLKS_PER_SAMPLE*sample_rate;
int m = (LPC_SC->PLL0CFG & 0xFFFF) + 1;
int n = (LPC_SC->PLL0CFG >> 16) + 1;
int cclkdiv = LPC_SC->CCLKCFG + 1;
int Fcco = (2 * m * XTAL_FREQ) / n;
int cclk = Fcco / cclkdiv;
//Power up the ADC
LPC_SC->PCONP |= (1 << 12);
//Set clock at cclk / 1.
LPC_SC->PCLKSEL0 &= ~(0x3 << 24);
<snip>
pclk = cclk / cclk_div;
clock_div=pclk / adc_clk_freq;
<snip>
_adc_clk_freq=pclk / clock_div;
<snip>
This is code is for setting the ADC clock, but you can easily modify it to read back rather than write the related registers. That will let you work out exactly how the ADC has been configured...
Hi, does anyone know exactly what the default settings for the clock are? I have looked through a few posts that seem to contradict each other. I am wanting to make sure the analogue channel is running at the maximum 200Khz.
