MODSERIAL, attach with member methods not working
09 May 2011
Hello All,
I am trying to use MODSERIAL in one of my drivers and cant seem to get the attach to happen when setting up a callback to a member method
void Driver::uartRead(MODSERIAL_IRQ_INFO *) {
    _pc->putc(_uart.getc());
    rxLed =! rxLed;
Driver::Driver(PinName tx, PinName rx, Serial* pc) : _uart(tx, rx) {
    _pc = pc;
    _uart.baud(DEFAULT_BAUD);
    _uart.attach(this, &Driver::uartRead, MODSERIAL::RxIrq);
    // make sure we are not in config mode!
    _uart.printf("Q%s",LINE_END);
Which gives me the compile time error. "No instance of overloaded function "AjK::MODSERIAL::attach" matches the argument list (E304)
Since I am new to CPP I am having a hard time locating the issue or is it simply a bug in MODSERIAL?
Thanks for any pointers, Serge
09 May 2011
Note, in the latest version the function prototype for the callback has changed from void funcname(void); to void funcname(MODSERIAL_IRQ_INFO *q);. See the docs and examples.
edit: if it's not working as expected, make sure you are using the latest library.
09 May 2011
Got it ...
Actually its connect and not attach in this case ... my bad.
Thanks, Serge
09 May 2011
I think this is what you are looking for:-
void Driver::uartRead(MODSERIAL_IRQ_INFO *q) {
    MODSERIAL *s = q->serial;
    s->putc(_uart.getc());
    rxLed =! rxLed;
// ** OR **
void Driver::uartRead(MODSERIAL_IRQ_INFO *q) { // NOTE, you still need the "q" even if not used.
    rxLed =! rxLed;
    _pc = pc;
09 May 2011
Oh, connect() is just supposed to be an alias of attach(). Maybe I missed something when adding the new callback system. I'll have a look.
10 May 2011
Fixed in v1.21 (just released). Thx.
10 May 2011
Thx Andy,
Confirmed ok.
16 Jan 2012
Right, the documentation should be fixed to match the library - it still specifies a void parameter for the callback function.
11 Dec 2012
Hello Andy,
I am getting compiler error on lines 61 and 68 in INIT.cpp:
"no instance of overloaded function "mbed::Serial::attach" matches the argument list" in file "MODSERIALINIT.cpp", Line: 61, Col: 66
I am using v27 of MOSERIAL and v53 of mbed.lib
thanks, ...kevin
12 Dec 2012
This was more a very old topic regarding a problem, see the cookbook page: http://mbed.org/cookbook/MODSERIAL (but yeah you were the first to report this one).
