math functions ?
02 Jul 2010
hello,
I'm very newby to C programming and I have some interrogation about the librairies
I need some mathematical function (log and exp mainly)
do I need a special librairy or ares these fonctions already in the main one ?
sorry for the basic question
02 Jul 2010
Math functions are provided by math.h, which is included by default.
  float x = exp(2.0);
  float y = log(x);
  printf("e^2 = %f, ln(e^2) = %f\n", x, y);
07 Jul 2010
thank you a lot
is there a list of the librairies included by defaut ?  to avoid other silly questions ;-)
07 Jul 2010
Hi Pion,
The standard c libraries we include by default within mbed.h are:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include <time.h>
FYI, at some point I'd like us to specify the definitions of all these standard c functions on mbed, but for now the following is a good reference:
Hope that helps.
Simon
07 Jul 2010
that definitly help
thank you a lot
16 Nov 2010
Hi there!
I'm guessing with previous posts is that <ctype> library is not included?
I need to use the function isdigit() which is in that library...any suggestions?
thanks!
16 Nov 2010
Use ctype.h instead.
16 Nov 2010
or
#include <cctype>
with std::isdigit()
21 Nov 2010
Hi, Thanks for the pointer to http://www.cplusplus.com/reference/clibrary/
I can't find M_PI in there, and the mbed compiler doesn't recognise PI or M_PI. I could just #define it locally, but I feel like I'm missing the 'clean' way to make nice code. Suggestions please?
Thanks in advance:
09 Feb 2011
Has anyone checked the accuracy of the math functions?
I am getting log(100.0) equal to 4.605170. It should be 2.0000 log(10.0) = 2.302585, s/b 1.0000 log(1.0) = 0.000, s/b 0.000 yeaaa!!!!, this one is correct log(0.1) = -2.302585, s/b -1.0000 log(0.01) = -4.605170, s/b -2.0000
I've tried float(log(100.0)) and double(log(100.0)), but the answer is the same.
Am I doing something wrong or is log broken? ...kevin
09 Feb 2011
Kevin -
The natural logarithm (ln) of 100 is 4.605170.
Perhaps the function you seek is log10().
- Gary
09 Feb 2011
log() returns the natural logarithm (ln), not base 10 (use log10 for that).
09 Feb 2011
that was it, thanks
18 Dec 2011
Are there many functions and defines missing in the mbed math library or am doing it wrong. Don't seem find lround, trunc, M_PI, etc...
Help appreciated.
31 Jan 2012
Help appreciated.
I seem to be hitting same problem...
But there is a solution. Put this in the header file of your project:
#ifndef M_PI
#define M_PI           3.14159265358979323846
#endif
#ifndef lround
#define lround(var)    (long)(var+0.5f)
#endif
15 May 2015
hello what function in MBED replaces the MAP function?
15 May 2015
hi what function in MBED replaces the MAP function?
15 May 2015
You mean the map function from Arduino? Just see: http://www.arduino.cc/en/Reference/Map. At the bottom there is the actual formula used by that function. It is a pretty simple one, so you can just copy that to your program and use it.
