6 years, 6 months ago.
Hard Fault w/ RA8875 & GSL1680 CTP on STM32F401RE Board
I'm running this code,
Import programPUB_RA8875_Touch
A Touchscreen example program showing the RA8875 driver library. This is easily configured for either the Resistive touch panel or the Capacitive touch panel.
on a NUCLEO-64 STM32F401RE board. I've run other tests and so far it appears that the screen writing functions are working well. I was trying to get the CTP (Capacitive Touch Panel) working with the www.buydisplay.com 5" LCD (https://www.buydisplay.com/default/5-inch-tft-lcd-display-capacitive-touchscreen-ra8875-controller-800x480).
I ran the PUB_RA8875_TouchColors demo code and that does seem to work as I'm seeing RGB color codes written to the serial port when I touch a color. Each touch sends multiple responses but that's a different issue.
This tells me that my hardware connections are correct (I also ran a completely different sample code using the Arduino IDE and that worked perfectly with the same hardware connections.
The only change in the code I made was the pin definitions:
Changes to Code
//RA8875 lcd(p5, p6, p7, p12, NC, p9,p10,p13, "tft");
// SPI:{MOSI,MISO,SCK,/ChipSelect,/reset}, I2C:{SDA,SCL,/IRQ}, name
RA8875 lcd(PA_7,PA_6,PA_5,PB_6,PC_7, PB_9,PB_8,PB_10,PA_8, "tft"); //For Nucleo-F401RE
The hard fault I get when I run the PUB_RA8875_Touch code is this:
Serial Port Output with Hard Fault
RA8875 Touch Screen Example - Build Nov  7 2019 21:23:06
++ MbedOS Fault Handler ++
                          FaultType: HardFault
                                              Context:
                                                      R0   : 20017FCC
        R1   : 0800        AFC5
    R2   : 0800AFC6
                   R3   : 0000003A
                                  R4   : 00000002
                                                 R5   : 00000003
        R6   : 0FFFFFFF
        R        7   : 00000032
              R8   : 0000000F
                             R9   : 20018008
                                            R10  : 00000001
                                                           R11  : 00000001
        R12  :        0000003A
         SP   : 20017FB8
                        LR   : 0800112D
                                       PC   : 0800AE56
                                                      xPSR : 01000000
        PSP  : 0000        0000
    MSP  : 20017F50
                   CPUID: 410FC241
                                  HFSR : 40000000
                                                 MMFSR: 00000000
        BFSR : 00000082
        U        FSR : 00000000
              DFSR : 00000008
                             AFSR : 00000000
                                            BFAR : 20018008
                                                           Mode : Thread
        Priv : P        rivileged
         Stack: MSP
                   -- MbedOS Fault Handler --
                                             ++ MbedOS Error Info ++
        Error Status        : 0x80FF013D Code: 317 Module: 255
                                  Error Message: Fault exception
   Error Value: 0x800AE56
                         For more info, visit: https://armmbed.github.io/mbedos-        error/?error=0x80FF013D
                       -- MbedOS Error Info --
Any help debugging why this hard fault is happening would be greatly appreciated!
Thanks, George
Hi
Maybe check if you are using correct pins in
https://github.com/ARMmbed/mbed-os/blob/master/targets/TARGET_STM/TARGET_STM32F4/TARGET_STM32F401xE/TARGET_NUCLEO_F401RE/PeripheralPins.c
Jerome
I can run the PUB_RA8875_TouchColors demo and it runs fine so I would believe that to mean that my connections and definitions are correct.
posted by George Ioakimedes 14 Nov 2019
