6 years, 10 months ago.
Temperature rating for Nucleo-F746zg (0C to 85C?)
What is the temperaturer range rating for the nucleo-F746ZG?
Thanks
I don't think you will get exact information as this board is for development only and not designed for a specific application environment.
In general most of today's components are usable between -10'c to +85'c, its the capacitors that limit temperature depending on the electrolyte used. However extreme temperatures will cause value changes in all components.
Hi
Check the MCU data sheet: https://www.st.com/resource/en/datasheet/stm32f746zg.pdf
Regards, Jerome
