7 years, 6 months ago.
STM32L053C8 UART/I2C Error in Mbed2 Latter Than Rev159
I am using a STM32L053C8 MCU and got some problems with it.
DigitalOut led(PA_14);
// Serial serial(PB_6, PB_7);
// I2C i2c(PB_14, PB_13);
while(1)
led = !led;
wait(0.1);
The code above works fine. However, when I un-comment the Serial or I2C, the LED stops blinking.
So I switch the MBED2 version to rev.159 (which looks like more stable) and un-comment the Serial and I2C and it works fine.
No idea what's going on. Any one could help?
The reason that I do not want to use the Rev.159 because it has some bugs on the LowPowerTicker lib.
Best
Hi
- serial(PB_6, PB_7): this could not work as PB6 and PB7 are using the same UART (UART_1) as the default STDIO.
- serial(PB_10, PB_11): this is OK as it is configuring LPUART_1 instance
Thanks Jerome, so can I disable the STDIO and use the UATR_1 for other propose? Because the above code works fine when using Mbed Rev159, I assume there is a way to do that.
posted by 05 Sep 2018Hi
LED was blinking, but I don't think that the new uart was working...
Check the wiki page: https://os.mbed.com/teams/ST/wiki/STDIO
It also works if I modified the Serial pins to (PB_10, PB_11) or the I2C pins to (PB_9, PB_8)
posted by Tony YI 01 Sep 2018
