10 years, 11 months ago.
Compiler messed up?
I've been compiling code that creates a 150k BIN file for a GR-PEACH. Over the past couple of days, sometimes the compiled BIN is only 83k or 94k. Of course, those images do not work at all. I am now only using "compile all". Still I get a much smaller BIN image than expected - about 1 out of 3 compiles.
...kevin
We are experiencing similar problems, very frustrating.
posted by Mordechai Brodt 01 May 2015
I'm getting a garbled binary file instead of a hex file when compiling BLE nano projects. Indeed, very frustrating!
posted by Tim Barry 01 May 2015
It's getting worse. Now, every 9 out of 10 compiles give the wrong BIN file size!!!
posted by Kevin Braun 01 May 2015
Same issue here. For FRDM-K64F. Just a pointer that when using the online compile REST API to get the binary same thing happens and the issue seems to be that the response content length is correct, but the response stream from the mbed server is incomplete (truncated at 84K)
posted by Dan Cristoloveanu 01 May 2015
Hi guys, is this still relevant ,as today?
posted by Martin Kojtal 04 May 2015
Problem still persists, not able to get correct hex files yet.
posted by Soumi Ghosh 04 May 2015
It seems that on-line compiler had some problems and those have been fixed already. Let me know if you still have the problem.
posted by Yasu Kutsuma 08 May 2015
10 years ago.
AS no further issues have been reported can we now consider this case closed? Please advise, very respectfully, Xtrm Designs LLC.
