9 years, 10 months ago.
Sd card library is creating problem in program. Cant see anything on LCD if add sdfile system code.
#include "TextLCD.h"
#include "SDFileSystem.h"
FileSystem sd(D9, D10, D12, D13, "sd");
TextLCD lcd(A0, A1, A2, A3, A4, A5);
DigitalOut switchengine(LED2);
DigitalIn pin_up(D6);
DigitalIn pin_down(D7);
InterruptIn pin_start(D8);
DigitalIn pin_delay(D11);
InterruptIn Pin_rain(PC_13);
Timer timer;
int Quarters;
void displayUpdate();
void startRun() ;
void callstart();
void timerf();
void pumpoff();
bool status ;
float delay;
int i;
int d;
int s;
int m;
float reverse;
float h;
float time;
int begin;
void rainsense();
time_t seconds = time(NULL);
//called when 15min has passed
void pumpoff(){
  switchengine=0;
    status = true;
   //update display
   lcd.cls();
   lcd.locate(3,0);
   lcd.printf("PUMP OFF!");
     lcd.locate(0,1);
    lcd.printf("Ran T:%1.2f Hr",i*0.25);
    pin_start.rise(&timerf);
   pin_start.fall(&callstart);
        Pin_rain.rise(&rainsense);
 void rainsense(){
    switchengine=0;
     lcd.cls();
   lcd.locate(0,0);
   lcd.printf("%s",ctime(&seconds));
   if(h<1.1){
        lcd.locate(0,1);
lcd.printf("Ran T:%1.2f Hr ",m);
       else{
   lcd.locate(0,1);
lcd.printf("Ran T:%1.2f Hr ",h);}
   FILE *file = fopen("/local/rainstamp.txt", "a");
     if(file == NULL) {
        fprintf(file, "Could not open file for write\r\n");
    else{
     fprintf(file, " \r set time- rantime-%1.2f,Rain time- %s,\n", h , ctime(&seconds));
fclose(file);
while(1){
     switchengine=0;
 void timerf(){
     timer.start();
 begin = timer.read();
 void callstart(){
          int end = timer.read();
          timer.stop();
          int t = end - begin;
     if(status==true ){
          if(t==2){
            startRun();
  timer.reset();
void displayUpdate(){
    //engine should be running
    if (i==0){
     pumpoff();
  else{
       switchengine=1;
    if(i<4){
                  m = i*2;
                 s = 60;
                  while(m > 0){
              lcd.cls();
              lcd.locate(3,0);
       lcd.printf("Time= %d min ",i*2);
       lcd.locate(2,1);
       lcd.printf(" %d min %d",m-1, s);
       wait(1);
       s--;
       if(s==0){
           m--;
           s = 60;}
           if(m==0){
         pumpoff();}
                  else{
                       s = 60;
                       h = i*0.25;
                      while(h > 0){
                          if(h<1.1){
                lcd.cls();
              lcd.locate(1,0);
       lcd.printf("Time= %1.2f Hr ",i*0.25);
       lcd.locate(2,1);
       lcd.printf(" %1.1f min  %d",(h-0.01)*100, s);
              else{
                  lcd.cls();
              lcd.locate(1,0);
       lcd.printf("Time =%1.2f Hr ",i*0.25);
       lcd.locate(2,1);
       lcd.printf(" %1.2f Hr  %d",h-0.01, s);
       wait(1);
       s--;
       if(s==0){
           h= h-0.01;
           reverse = reverse+0.01;
           s = 60;}
           if(h==0){
             pumpoff();}
//update the display and start/stop the engine
// init and start the run
 void startRun() {
 status = false;
 lcd.cls();
 lcd.locate(3,0);
 lcd.printf("PUMP START");
 wait(1);
 lcd.cls();
 displayUpdate();
  pin_up.mode(PullDown);
  pin_down.mode(PullDown);
  pin_start.mode(PullDown);
  pin_delay.mode(PullDown);
 //mkdir("/sd/mydir", 0777);
  set_time(1458986114);
  if(reverse < (i*0.25)){
     lcd.locate(0,1);
    lcd.printf("Ran T:%1.2f Hr",reverse);
  if(switchengine==0){
            lcd.cls();
        lcd.locate(5,0);
        lcd.printf("READY");
        wait(1);
             lcd.cls();
        lcd.locate(3,0);
        lcd.printf("SET TIME");
             do{
                 while(pin_delay == 1){
        d++;
        lcd.cls();
        lcd.locate(0,0);
        lcd.printf("DELAY = %d mn", d);
        wait(0.8);
          if(pin_up==1)
           {i= i++;
           wait(0.1);
           if (i>200)
            i=200;
            tim = i;
            if(i<4){
             lcd.cls();
             lcd.locate(1,0);
             lcd.printf("Time= %1.2f mn", tim*15);
             else{
                 lcd.cls();
                 lcd.locate(1,0);
             lcd.printf("Time= %1.2f Hr", tim*15/60);
                 else if(pin_down==1){
                     i=i--;
                     wait(0.1);
                     if( i<0)
                     i=0;
                     tim = i;
                     if(i<4){
                         lcd.cls();
                         lcd.locate(1,0);
              else{
              lcd.cls();
              lcd.locate(1,0);
              lcd.printf("Time= %1.2f Hr",tim*15/60);
                     } while(pin_start==0);
if(i==0){
  while(1){
  lcd.cls();
 lcd.locate(3,0);
  lcd.printf("Error!!!");
  lcd.locate(1,1);
  lcd.printf("Time not set");
  wait(3);
  tim = Quarters; //Initial selected number of quarters
    if(d==0)
    startRun() ;
else
              int sec = 60;
              int min = d*15;
              if(d<4){
                  while(min>0){
              lcd.cls();
       lcd.locate(1,0);
       lcd.printf("Wait =%d min %d",min-1, sec);
       wait(1);
       sec--;
       if(sec==0){
           min--;
           sec = 60;}
           if(min==0){
           d=0;}
                  else{
                       int sec = 60;
              float hr = d*0.25;
                      while(hr>0){
              lcd.cls();
       lcd.locate(0,0);
       lcd.printf("Wait= %1.2f Hr %d",hr-0.01, sec);
       wait(1);
       sec--;
       if(sec==0){
           hr= hr-0.01;
           sec = 60;}
           if(hr==0){
               d = 0;}
      startRun();
                  // call to (re)start engine run)&& status == true if(runtimeleft == 0 )
    while(1);       // just wait for keypress
Affordable and flexible platform to ease prototyping using a STM32L152RET6 microcontroller.
1) Use the format option in the compiler.
2)
   if(file == NULL) {
????????? You check if the file pointer is invalid and then try to use it anyway? If you are getting a null pointer that's going to cause a crash.
posted by Andy A 08 Jun 2016
Do you mean to say if I am running the program in the controller without SDcard breakout board, just for test, the whole program wont work? because I was running program just to test without connecting any sdcard.
posted by jayendra mishra 08 Jun 2016
Assigned to Simon Ford 9 years, 9 months ago.
