11 years ago.
The build system is under heavy load right now.
I cannot compile my source file because of this problem. When will it fixed?
8 years, 9 months ago.
Hello everyone,
We are growing pretty constantly these days. More users means more load on the online compiler. We monitor the usage and try to bump up the size and number of the servers that back the online compiler whenever we seem to be exceeding their capacity.
As far as offline tools go, we have a tool, mbed CLI, for development offline. You can find it here: https://github.com/ARMmbed/mbed-cli . developer.mbed.org has a convenient "Import with mbed CLI" button (it's a drop down option on the "import into online compile" button) that gives you the command needed to import a project with mbed CLI.
Thanks, Jimmy
11 years ago.
Same here. Hoping this will be fixed soon.
/media/uploads/okano/heavy_load.png
11 years ago.
Same here.
11 years ago.
im also have problem with it
11 years ago.
Completely unimpressed.
11 years ago.
Yup, I too have the same problem. Also, I am getting a page error, had to try a few times to post this comment...
11 years ago.
Hope the error will be rectified at the earliest
11 years ago.
I also have the problem...
11 years ago.
Same
11 years ago.
+1, same here
11 years ago.
This was happening yesterday also. It would be nice if there was a response from the moderators about this? I have not seen any response so far. I am trying to work and this is extremely inconvenient to say the least.
11 years ago.
same problem
11 years ago.
Today is the 2nd day I am sitting in office simply waiting for the compiler to start working again. We're under a deadline! Does anyone have a workaround? I think I have to seriously start looking at an offline toolchain.
11 years ago.
Obviously this is one of the reasons an online compiler is such a terrible idea, even for a hobbyist it's a pain, for a business it's a disaster.
You are at the mercy of someone else's computer equipment, and without any Service Level Agreement. And running lots of servers gets expensive...
11 years ago.
it should be fixed. I can compile now.
11 years ago.
I don't think the online compiler is a terrible idea Bob, I believe it may have become overstretched now with claims of 100,000 Mbed users it will be buckling under pressure. This problem started several months ago and has been getting worse. What is needed is an offline compiler facility or version that is tuned to the available platforms that are on Mbed.
The Mbed compiler is using Keil which I believe is owned or a subsidiary of ARM. UVision 32K free version is outdated in size and perhaps some consideration should now be given to increase this inline with others such as Code Red that has now doubled its free use to 256K for LPCExpresso.
An integrated Keil Mbed version would be the way to go. Its not too difficult to keep the online concept but have the compiler resident on the user's PC. This would dramatically reduce the overhead on Mbed's systems at the same time keeping that online community alive. Mbed library updates would remain readily available like it is now and still retain that easy to use IDE.
So what is happening now???
I am having this issue right now
Same here!
Having same issue now.
Expected response: "We are looking into it and it should be resolved shortly"
cant compile again.can we have offline version of mbed??
11 years ago.
I cannot compile my source too. Is there any action to solve this problem?
