11 years ago.
GR-PEACH startup questions
I just received a GR-PEACH. I see the mbed drive and all of the LEDs are flashing. TeraTerm connects to the newly found USB-serial port.
1. How do I determine the firmware version?
2. What application code is shipped with the GR-PEACH?
3. Is there any serial output data from the application code? If so, what is the baud rate?
Regards
11 years ago.
Hi Kevin,
I think this question is the same as the following your question that I already answered.
Is my understanding correct and OK for you?
How to determine the firmware version on GR-Peach
Best Regards,
Masahiko Ikeda
Hi Kevin, can you be so kind to give me tip where is possible to buy GR-PEACH ? Thanks, Ales.
posted by Ales Burian 26 Mar 2015
