10 years, 2 months ago.
Why pc.baud(115200); doesn't work?
Why pc.baud(115200); doesn't work for change baud rate virtual com port doesn't work? But for LPc and Freescale working well.
Hello, It works perfectly fine for me. Are you sure the problem is not comming from something else?
This code: https://developer.mbed.org/users/mlee350/notebook/adafruit-ultimate-gps-breakout-board/
if myGPS.begin(9600) pc.baud for virtual com port too 9600. and no matter if I set pc.baud(115200); And if I change platform to LPC1768 or frdm K22f all work well.
posted by 29 Jan 2016Your GPS isn't somehow using the same UART as the virtual com port is is? I've seen things like you are describing when the same UART has been mapped to two sets of pins.
