12 years, 11 months ago.
emWin and mbed
Is it possible to use emWin in mbed environment?
This one is also interesting : http://www.lpcware.com/content/forum/does-emwin-support-lpc17681769#comment-1959
Links to http://coineltech.com/index.php?main_page=product_info&cPath=8&products_id=14
The CodeBundle download contains EmWin (ported to LPC1768) used with their ILI9325 based 3.2" SPI TFT (http://coineltech.com/index.php?main_page=product_info&cPath=21&products_id=29)
Using codebundle by coineltech the problem is the same of MCB1700
posted by Davide Luongo 20 Mar 2013
Hi thank you very much for the answer I've downloaded the BSP for MCB1700 I can using this software on my Mini-DK but a need to reconfigure active SPI pins. This is the function of pins initialization. I'm not good to use KEIL uVision4 how change the pins?
SPI init
pins are:
   - CS     = P0.6 (GPIO pin)
   - SCK    = P0.7 (SCK1)
   - SDO    = P0.8 (MISO1)
   - SDI    = P0.9 (MOSI1)
my pins are:
   - CS     = P0.18 (GPIO pin)
   - SCK    = P0.17 (SCK1)
   - SDO    = P0.19 (MISO1)
   - SDI    = P0.20 (MOSI1)
* Initialize SPI (SSP) peripheral at 8 databit with a bitrate of 12.5Mbps      *
*   Parameter:        *
*   Return:        *
void LCD_X_SPI_Init(void)
  uint8_t Dummy;
  /* Enable clock for SSP1, clock = CCLK / 2 */
  LPC_SC->PCONP       |= 0x00000400;
  LPC_SC->PCLKSEL0    |= 0x00200000;	/* PCLK = CCLK / 2 = 50MHz */
  /* Configure the LCD Control pins */
  LPC_PINCON->PINSEL9 &= 0xF0FFFFFF;
  LPC_GPIO4->FIODIR   |= 0x30000000;
  LPC_GPIO4->FIOSET    = 0x20000000;
  /* SSEL1 is GPIO output set to high */
  LPC_GPIO0->FIODIR   |= 0x00000040;
  LPC_GPIO0->FIOSET    = 0x00000040;
  LPC_PINCON->PINSEL0 &= 0xFFF03FFF;
  LPC_PINCON->PINSEL0 |= 0x000A8000;
  /* Enable SPI in Master Mode, CPOL=1, CPHA=1 */
  /* 12.5 MBit used for Data Transfer @ 100MHz */
  LPC_SSP1->CR0        = 0x1C7;		/* SCR = 1 */
  LPC_SSP1->CPSR       = 0x02;		/* CPSDVSR  = 2. Bit frequency = PCLK / (CPSDVSR × [SCR+1]) = 50 / (2 × [1+1]) = 12.5Mbps */
  LPC_SSP1->CR1        = 0x02;
  while(LPC_SSP1->SR & (1<<2))
    Dummy = LPC_SSP1->DR;			/* Clear the Rx FIFO */
  LPC_GPIO4->FIOSET = 0x10000000;	/* Activate LCD backlight */
You should either post another question or start a forum discussion. Also, please use <<code>> tags.
posted by Igor Skochinsky 20 Mar 2013
solved
uVision 4 project for the Mini-DK is available at http://mbed.org/users/frankvnk/notebook/lpc1768-mini-dk---nxp-segger-emwin/
posted by Frank Vannieuwkerke 01 Apr 2013
