I had one of these enclosures built. I have a couple more comments and suggestions for the enclosure.
1. I believe having a 13mm x 1.5mm slot for the SD Flash out of the back of the enclosure is essential.
2. Need to re-think how the USB connector is laid out. The mating connector barely makes contact with the K64F and falls out easily. I suggest:
a. Move PCB 1.1mm closer to the edge of the enclosure (USB side) -and-
b. Make the enclosure 1.0mm thinner (or perhaps removed entirely) in a 11.5mm x 7mm area surrounding the USB connector. This is to allow room for the mating USB cable's over-mold.
...kevin
Hi
We are testing the FRDM-K64F in some remote rural areas. We want to protect the boards with a good enclosure - do any 3rd party products exist ?
If there are no known enclosures for this, does anyone have the measurements of the board including its mounting holes and perimeter ? I cannot find this in the documentation.
Thanks! Andy
