The Freedom-K64F is an ultra-low-cost development platform for Kinetis K64, K63, and K24 MCUs.
any ideas for a FRDM-K64F enclosure?
11 Jan 2016
Hi
We are testing the FRDM-K64F in some remote rural areas. We want to protect the boards with a good enclosure - do any 3rd party products exist ?
If there are no known enclosures for this, does anyone have the measurements of the board including its mounting holes and perimeter ? I cannot find this in the documentation.
Thanks! Andy
11 Jan 2016
Not much help on this so I went ahead and modelled one in Autodesk Fusion 360:
/media/uploads/andymeira/frdm-k64f_case_generic_v1.png
You can download the bottom and top STL files attached here and 3d print for yourself.
Case bottom part: /media/uploads/andymeira/frdm_bottom.stl
Case top part: /media/uploads/andymeira/frdm_top.stl
The design files are here - if you modify this design please upload here so we can re-use : http://a360.co/1l1gqXa
15 Jan 2016
Thank you Andres! Looks great!
15 Jan 2016
Looks lovely!
I'd like to note that for 3d Printing (FDM) the undercut of the screw holes on the "wings" on the side mean it can't print without support. Likely this was designed with injection molding in mind?
For 3D FDM, the underside of the mounting wings would need to be filled in and flat. (Similarly the top cover gets printed "upside down")
18 Jan 2016
Thanks Iain good catch. I updated the model for 3d printing with filled in wings as you suggest:
I believe you can download the STLs also from this link.
cheers
12 Feb 2016
Hi guys!
Can anyone suggest me where can I find detailed dimensions of this board, or even better 3d model? I can't find a datasheet with dimensions of mount holes...
Thank you for your help. Miha
12 Feb 2016
Mika,
I believe the FRDM boards all have the same dimensions and positions for the mounting holes. This old thread on the Freescale community has some info for the KL25Z. This says the mounting holes are 125 Mil ± 3 Mil.
Steve
15 Feb 2016
here u go.
/media/uploads/andymeira/capture.jpg
I got the dims from the gerber file. I printed in 3d and confirm this works.
16 Feb 2016
That is what I was looking for. Thank you for sharing! Just one more question. Does this board comes with pin headers already soldered on board?
06 May 2016
Hammond Manufacturing may have one that works. Available at this link. http://www.mouser.com/Search/ProductDetail.aspx?qs=c8305KrhTpw1RPJNdfJY7g%3d%3d
10 May 2016
Can the file be modified to allow for the SD Flash card coming out of the rear of the enclosure?
24 May 2016
I had one of these enclosures built. I have a couple more comments and suggestions for the enclosure.
1. I believe having a 13mm x 1.5mm slot for the SD Flash out of the back of the enclosure is essential.
2. Need to re-think how the USB connector is laid out. The mating connector barely makes contact with the K64F and falls out easily. I suggest:
a. Move PCB 1.1mm closer to the edge of the enclosure (USB side) -and-
b. Make the enclosure 1.0mm thinner (or perhaps removed entirely) in a 11.5mm x 7mm area surrounding the USB connector. This is to allow room for the mating USB cable's over-mold.
...kevin
26 Jul 2016
Hello Andy,
You're design looks great. I don't have Solidworks or any other software that facilitates editing models, I think. Would you be so kind to remove the wings so the case is a standard box (like most Arduino and Raspberry ones) and make the new model available? It's just a request, so if you're too busy simply ignore. Thanks again.
Michael
You need to log in to post a reply
