KS0108 LCD
17 Mar 2010
Hey Guys!
Could someone tell me if there is any API to interface with a 128x64 graphical LCD ( I got it from here: http://www.sparkfun.com/commerce/product_info.php?products_id=710), I believe it uses the KS0108 chipset. I've attached a picture of the LCD below. I'm using the 1768 mbed.
Thanks in advance.
-Devesh
19 Mar 2010
Made this a while back. It's not the best written code in the world but should work.
Displaytest
19 Mar 2010
@Anders: Thanks! It works perfectly. =)
-Devesh
19 Jun 2010 . Edited: 19 Jun 2010
Edit:   Never mind, I figured it out!
20 Aug 2010
Hi guys:
Can you send a photo or data table with the pin connections between the display and mbed?
Thank's in advance.
20 Aug 2010
What is the file Display.h included in the Displaytest program? It doesn't seem to be part of your project.
20 Aug 2010
If you select import program in the compiler window, and import DisplayTest, it would bring in the Display library as well.
Alternatively, select your current project (the one with DisplayTest but without the liobrary), right click, select import library and chose Display from the list in the lower pane.
Make sure you have import as library selected.
20 Aug 2010
Thanks, Romilly.
21 Aug 2010
I found pin connections on source code  :
Display (PinName _RS, PinName _RW, PinName _E, PinName _CS1, PinName _CS2, PinName DB0, PinName DB1, PinName DB2, PinName DB3, PinName DB4, PinName DB5, PinName DB6, PinName DB7);
Thanks guys
