Can some one point me to an idiots guide to using the attach function with serial input.
What I would like to do is use attach to direct the interupt to a function that sets a flag that the main program uses as a signal to tell it to get data from the serial port. This avoids the need for my code to be always monitoring the serail port.
The code below shows a very much simplified version of what i am trying to do. It works to the point of setting the flag but subsequent attempts to send data over the serial port cause the code to go into a loop in my responftoPC function.
void respondtoPC() ;
DigitalOut myled(LED1);
main()
struct tm t;
volatile int test ;
test = 0 ;
pc.attach( respondtoPC) ;
while (1)
myled = !myled ;
if ( test == 1 )
printf("Enter current date and time: \n");
printf("YYYY MM DD HH MM SS[enter] \n");
scanf("%d %d %d %d %d %d", &t.tm_year, &t.tm_mon, &t.tm_mday
, &t.tm_hour, &t.tm_min, &t.tm_sec);
// adjust for tm structure required values
t.tm_year = t.tm_year - 1900;
t.tm_mon = t.tm_mon - 1;
// set the time
set_time(mktime(&t));
printf("set time\n");
wait(1) ;
void respondtoPC()
char dummy ;
dummy = pc.getc() ;
test++ ;
return ;
It seems to me that either I have the major structure wrong or I have my respond code wrong. Of course there may be another explanation.
Thanks in advance.
Allan
main()
struct tm t;
volatile int test ;
test = 0 ;
while (1)
myled = !myled ;
if ( test == 1 )
// set the time
wait(1) ;
void respondtoPC()
char dummy ;
dummy = pc.getc() ;
test++ ;
return ;
Thanks in advance.
Allan
