Hi Voy,
Is your problem that you have not managed to get a webserver running, or that in adapting a webserver to do what you want it "hangs" somehow?
The place to start is probably the HTTP Server in the cookbook. If you can get that running without modification you'll know you have your hardware and network setup correctly. If that doesn't work, then I expect something about your hardware or network needs adjusting.
Once you have that working, it should not be too hard to add your own logic to do things based on requests. If you are still having trouble after trying the HTTP Server examples, it may be worth posting a bit more context and information about what you are doing and the problems you are having to give people a chance to help you out.
Simon
Has anybody got the code of a working webserver for switching the lights on the mbed without RPC ? After trying the whole day all kind of progs from the Forum i got fed up now. Not a single webserver is working without a hanging.
