using Ticker inside a class
08 Mar 2011
I have a class definition with a ticker object declard in the task as well as a function inside the task. I get a compile error when I call the attach function.
Sequence.h
class Sequence
public:
	// construction/destruction
	Sequencer( void );
	~Sequencer( void );
private:
	Ticker		tickSeq;
	// ticker
	void ProcessTicker( void );
Sequence.c
Sequence::Sequence( )
	// create the ticker
	tickSeq.attach( &ProcessTicker, 1.0 );
08 Mar 2011
If you want to use a method (as opposed to a plain function), you need to pass the class instance too. Try:
tickSeq.attach(this, &ProcessTicker, 1.0);
08 Mar 2011
I think it's actually:-
Sequence.c
	tickSeq.attach(this, &Sequence::ProcessTicker, 1.0 );
08 Mar 2011
Worked great. Thanks
23 Oct 2013
Thank you. :)
30 Dec 2016
The mbed-os now requires the callback to be added otherwise the function warning of depreciating will be indicated :
tickSeq.attach(callback(this, &Sequence::ProcessTicker, 1.0 );
09 Feb 2017
The correct Syntax will be:
tickSeq.attach(callback(this, &Sequence::ProcessTicker), 1.0 );
You missed closing bracket.
10 Feb 2017
Along those same lines, I have this simple class definition, which essentially inherits class USBSerial:
#include "USBSerial.h"
class inherit_USBSerial : public USBSerial {
  public:
    inherit_USBSerial() : USBSerial() {}
inherit_USBSerial xxx; // just completely inherit class USBSerial
int main(){ xxx.printf("Hello World\n"); }
I get this warning:
Warning
Function "mbed::FunctionPointerArg1::FunctionPointerArg1(R (*)()) [with R=void]" (declared at/extras/mbed_176b8275d35d/platform/FunctionPointer.h:67) was declared "deprecated" in "USBDevice/USBSerial/USBSerial.h", Line: 59, Col: 205>
Since the warning is about a void function pointer, can I do something to stop the warning?
10 Feb 2017
Also, changing USBSerial.h line 59 from
    USBSerial(uint16_t vendor_id = 0x1f00, uint16_t product_id = 0x2012,
                             uint16_t product_release = 0x0001, bool connect_blocking = true)
      : USBCDC(vendor_id, product_id, product_release, connect_blocking)
    {  settingsChangedCallback = 0;    };
to
    typedef void (* fptr4)(int,int,int,int); // a void function pointer with 4 int parameters
                            uint16_t product_release = 0x0001, bool connect_blocking = true, fptr4 callback = 0)
    { settingsChangedCallback = callback;  };
did not make the the warning go away - even though the added callback does work when USB serial port settings are changed.
