Hi Neal,
The c libraries are stored and linked within the compiler backend, and they aren't actually anywhere on the site. However, they are the armcc standard libraries, so you can look at all the documentation here:
Hope that has all the information you need. Please shout if not.
Thanks!
Hi Simon,
Thanks for replying.
I do understand that the C libraries are stored and linked within the compiler backend.
I am not looking for the source to the implementation of the libraries.
I am looking for the header files as used by the compiler.
I did look at the docs that you linked to, but I didn't see the header information. Maybe I missed it.
I would like to look at the implementation of a few structures as would normally be declared in the library headers.
Normally, for any compiler environment that I've used, I can go look in the header files, to see exactly how a given structure or function is declared or prototyped, be it windows, unix, or embedded whatever... On unix, I can `man localtime' and get all the info relative to `struct tm'. There appears to be no equal here for mbed.
This is the normal minimum documentation that I'd expect, excluding all other documentation.
That is what I want to do now. Specifically, I want to look at `struct tm'. The compiler is complaining that it doesn't have the tm_gmtoff member. I want to see if it has something similar, or try to find the C library's concept / implementation / representation of time zone, if it exists. If it doesn't exist, then I need to maintain that on my own, that is ok too. But, I'd like to try and use what is already in the library.
If the headers are not available on the mbed site, but I need to download them and examine them offline, then that is fine, I don't care. I just want to be able to search / look at them.
i'm not trying to be a jerk or whatever...
What way should I use to find this kind of information ?
Where on earth do I find the the headers for the C, and C++ libraries that are used by the online compiler ?
TIA
