I upgraded from revision 26 to 35 and my code slowed down from updating at 1600 Hz to 1400 Hz. How do I downgrade the mbed library version so that I can figure out exactly what revision caused this?
It generates data for cascaded TLC5947 which is a 24 channel 12-bit shift register for driving LED's. The code does pure integer HSV to RGB and has a look-up table for gamma correction. The update frequency is measured by looking for the latch() call on an oscilloscope.
I also noticed my binary size shrank from 35KB to 24KB but I'm not sure what that means exactly.
For reference, here is my test program: http://mbed.org/users/allanw/programs/rgbstick/m3w6df
Hi Allan,
You can just delete the mbed library and reimport at the specific version using @, so in this case you'd imprt using the url:
http://mbed.org/projects/libraries/svn/mbed/trunk@26
Hope that is what you were after,
Thanks. I found there's a 10% speed regression between 31 and 32. I've made a smaller testcase program and found that the problem is purely due to the SPI calls. I'll post in the bugs forum with more details.
Cookie Policy
Access Warning
