Hi David,
You can actually use freopen to redirect things like stdout and stderr, so with a bit of thought you should be able to do some experiments to come up with something you are happy with. There is no /dev/null device as it stands, and you are in uncharted territory, but for some hints, see:
Not sure whether the various libraries you are actually are actually using the stderr, but I think you are right that it would be good to make sure it is more of a convention for debug output.
We do have the function error(fmt, ...)
which basically maps to fprintf(stderr, fmt, ...); exit(1)
i.e. it is a fatal error. Perhaps we could also have debug(fmt, ...)
which would map to fprintf(stderr, fmt, ...)
, and could be a more standard way of outputting debug warnings.
Simon
Quite a number of the available libraries apparently output messages (perhaps to stderr). As I'm also using serial on USB, this is woven into my own communications.
Is there a convenient means to trap stderr or route it to the bit-bucket for those times I don't want it?
If, on the other hand, these libraries are simply printing and cannot be separated, then perhaps a standardized log error mechanism could be developed?
Dave
