problem with implimenting differential drive for robot
06 Oct 2010
My main problem is understanding how to use the motor library to drive an h-bridge with 2 motors.
I'm new to mbed and so far I love it, but i'm used to the simpler Arduino. Any pointers would be helpful.
P.S. Using L293 h-bridge and two small 6v motors for testing.
06 Oct 2010
How did you do it in Arduino? Can you post a small code snippet?
06 Oct 2010 . Edited: 06 Oct 2010
Here is the code I used to make sure the setup worked as exected.
// h bridge test //
int enablePin1 = 10;    // Enable for Motor 1
int enablePin2 = 11;    // Enable for Motor 2
int motor1Pin = 2;    // Motor1A
int motor2Pin = 3;    // Motor1B
int motor3Pin = 4;    // Motor2A
int motor4Pin = 5;    // Motor2B
void setup() {
  pinMode(enablePin1, OUTPUT);
  pinMode(enablePin2, OUTPUT);
  pinMode(motor1Pin, OUTPUT);
  pinMode(motor2Pin, OUTPUT);
  pinMode(motor3Pin, OUTPUT);
  pinMode(motor4Pin, OUTPUT);
  digitalWrite(enablePin1, HIGH); //comment line if enable pins are tied to Vcc
  digitalWrite(enablePin2, HIGH); //comment line if enable pins are tied to Vcc
void loop() {
  digitalWrite(motor1Pin, LOW);   // set leg 1A of the H-bridge low
  digitalWrite(motor2Pin, HIGH);  // set leg 2A of the H-bridge high
  digitalWrite(motor3Pin, LOW);   // set leg 1B of the H-bridge low
  digitalWrite(motor4Pin, HIGH);  // set leg 2B of the H-bridge high
  delay(2500);
  digitalWrite(motor1Pin, HIGH);  // set leg 1A of the H-bridge high
  digitalWrite(motor2Pin, LOW);   // set leg 2A of the H-bridge low
  digitalWrite(motor3Pin, HIGH);  // set leg 1B of the H-bridge low
  digitalWrite(motor4Pin, LOW);   // set leg 2B of the H-bridge high
  delay(2500);
Here is PWM test code
  const int motorAPin1 = 8;   // AIN1
  const int motorAPin2 = 9;   // AIN2
  const int motorBPin1 = 10;  // BIN1
  const int motorBPin2 = 11;  // BIN2
  const int enablePin = 2;    // H-bridge enable pin
  const int ledPin = 13;      // LED
  const int PWMA = 3;         // Pulse Width Modulation Motor A
  const int PWMB = 5;         // Pulse Width Modulation Motor B
  void setup() {
    // set outputs:
    pinMode(motorAPin1, OUTPUT);
    pinMode(motorAPin2, OUTPUT);
    pinMode(motorBPin1, OUTPUT);
    pinMode(motorBPin2, OUTPUT);
    pinMode(enablePin, OUTPUT);
    pinMode(ledPin, OUTPUT);
    pinMode(PWMA, OUTPUT);
    pinMode(PWMB, OUTPUT);
    // set enablePin high so that motor can turn on:
    digitalWrite(enablePin, HIGH);
  void loop() {
    analogWrite(motorAPin1, LOW);
    analogWrite(motorAPin2, HIGH);
    analogWrite(motorBPin1, LOW);
    analogWrite(motorBPin2, HIGH);
    analogWrite(PWMA, 60);
06 Oct 2010
The code for the mbed will be even simpler than the Arduino :)
You can use DigitalOut objects for the H-bridge enable/motor pins, e.g.
DigitalOut enablePin1 = p10; //Enable pin for Motor 1
instead of
And PwmOut objects for H-bridge PWM pins e.g.
PwmOut pwmA = p3; //PWM Motor A
instead of
int PWMA = 3 // Pulse Width Modulation Motor A
You can check out the APIs for the DigitalOut and the PwmOut classes to find out how to use them.
07 Oct 2010 . Edited: 07 Oct 2010
Thank you
Your right that is simpler! :-) I thought this was gonna be a hard learning curve. Especially since I'm not that good with the Arduino!
P.S. how does the period efect the motor? e.g.
servo.period(0.020); // servo requires a 20ms period
Also in this statement does += mean the same as ++ as used with arduino?
while (1) {
        for(float offset=0.0; offset<0.001; offset+=0.0001) {
            servo.pulsewidth(0.001 + offset); // servo position determined by a pulsewidth between 1-2ms
            wait(0.25);
SubMicro
+= is not the same as ++.
It is almost the same function, except when using += you can define the number of increments, either by a number or a variable.
Example of ++:
int var=1;
var++; //the same as var=var+1, -> var is now 2
Example of +=:
int var=1;
var+=2; //the same as var=var+2, var is now 3.
If you are new to C/C++, I recommend this webpage for the basics of the language:
http://www.cplusplus.com/
More specific to the last question... Operators:
http://www.cplusplus.com/doc/tutorial/operators/
07 Oct 2010
Thank you for the info and reference links.
