Hello!
I use an InterruptIn for detecting a switch-change. The switch is directly connect to the mbed without an external Pull Up.
When I start or reset mbed, the Interrupt always triggers once. But the switch was not pressed.
Here is a test-programm:
//define digital interrupt pin
InterruptIn intPin(p23);
// callback function when interrupted
void trigger() {
     pc.printf("\n\rtriggered\r\n");
    //wait(1);
    pc.printf("\n\rConnected to mBed\r\n");
    intPin.mode(PullUp);          // Enable internal pullup
    wait(1);                        // no effect
    intPin.fall(&trigger);          // Call function
    //intPin.rise(&trigger);        // Call function
        wait(1);
        pc.printf(".");
Output:
Connected to mBed
triggered
Changing PullUp / PullDown has no effect on the "startup-trigger".
Waiting after setting the pin to PullUp doesn't change this.
How can I prevent InterruptIn from triggering on startup?
Regards - Charly
Hello!
#include "mbed.h" //define digital interrupt pin InterruptIn intPin(p23); Serial pc(USBTX, USBRX); // tx, rx // callback function when interrupted void trigger() { pc.printf("\n\rtriggered\r\n"); } int main() { //wait(1); pc.printf("\n\rConnected to mBed\r\n"); intPin.mode(PullUp); // Enable internal pullup wait(1); // no effect intPin.fall(&trigger); // Call function //intPin.rise(&trigger); // Call function while(1) { wait(1); pc.printf("."); } }Output:Changing PullUp / PullDown has no effect on the "startup-trigger".
Regards - Charly
