You do not have the correct permissions to perform this operation. Please, contact us at support@mbed.com to gain full access.
After double click on an error in the compiler output, you are taken to the problematic line of code - very handy. But the Program Workspace - the lefthand panel in the compiler - does not select the correct file.
This can be frustrating if, for example, you are working on important.c and compile with errors. If you double click on an error to fix it and want to return to important.c you must first select a different file and then select important.c.
It's a minor problem, but it's annoyed me enough times now to report it.
