"Fatal Application Error: Resource object failed to load.
Please contact support and describe how you get this message."
I'm getting this message every time I import local file into the compiler. Seems to not break anything though.
However, I tried "Import library", and this message shows up. Then the drop-down box in "Target Path:" is empty and "Import" button is grayed out. This prevents any library import whatsoever. Can't use the compiler!
I have quite a number of projects accumulated in my workspace. I was thinking of deleting all to see if it helps, but it will take a long time to backup and restore.
Is there another solution?
