Precompiled Libraries for faster Compiling
02 Feb 2012
Hey guys! I am developing a project using 7 additional libraries. Each time I compile the project, all Libs were compiled. This takes a lot of time, I only can wait. What about caching compiled Libraries? For an hour or two, this would be not too much memory and would rise the compiling speed.
Too some Source-Files (or better all) should be compiled only if changed.
05 Feb 2012
Hi Peter,
Compiler should be back to normal for you now; one of our compiler servers needed some unblocking, but now fixed. Tell us if you see any more problems.
Re: pre-compiled libraries. We've just been planning out our next project priorities, and an update to the build system to speed this up is one of the items we'll be working on. SHould make it all much faster when dealing with libraries. I'll perhaps share some of the main things we'll be working on over the next few months if that would be interesting.
03 May 2012
Simon Ford wrote:
Hi Peter,
what's the status of the above... or is there some method we can use to avoid, say, in using NetServices, a big recompile of all the sources for a small user program.
03 May 2012
Hopefully dan will announce a beta for incremental compiles today :)
It'll be the first of a few updates you should see this month as we roll out the new functionality that has been in the works for a while...
03 May 2012
better yet... The mbed IDE could/should keep track of which sources have changed and recompile only those. As we know, that's how IDEs normally work. For mbed's online compiler, perhaps a compromise is to compile all sources first time, then keep track of changed sources from there and avoid repeated recompilation of unchanged sources. This, in case precompile (ar files?) are hard to maintain with mbed.
04 May 2012
first run - NICE!
