6 years, 10 months ago.
SPI Slave sending wrong Data
Hi, I am trying to connect two STM32F7 with Mbed OS over SPI to benchmark the communication. The MOSI communication is working without problems. The slave also sends some right messages, but after sometime it sends a wrong byte and then the error is continuing. My main question is why the slave shifts the bytes wrong into the buffer? I think the error continuing is because of the FIFO buffer. Here is my Slave Code:
slave.cpp
SPISlave slave(PB_5, PB_4, PB_3, PA_4); // mosi, miso, sclk, ssel
DigitalOut GpioEn(PA_7,1);
DigitalIn TestStart(PA_6);
void clearBuf(char *buffer,int size){
for(int i=0;i<size;i++) buffer[i]=1;
unsigned int compare(char *buffer, char *buffer2,int size){
for(int i=0;i<size;i++) {
if(buffer[i]!=buffer2[i]) {
return 1;
return 0;
void printbuf(char *buffer, int size){
for(int i=0;i<size;i++) printf("%c",buffer[i]);
printf("\r\n");
////////PROGRAMMSTART////////
// COUNTER VARS //
unsigned int ErrCount = 0;
unsigned int mosi = 0;
//BUFFER INITS START//
volatile char sendBuf[]="Slave!";
char recBuf[7]={'0'};
char cmp[]="Master";
//BUFFER INITS END//
//SPI INIT START//
slave.frequency(1000);//max 54000000
slave.format(8,0);
//SPI INIT END//
wait(1);
slave.reply('a');
while(TestStart.read()==0) ;
while(TestStart.read()==1)
GpioEn=0;
if(slave.receive())
GpioEn=1;
for(int i=0;i<6;i++)
slave.reply(sendBuf[i]);
recBuf[i] = slave.read();
mosi++;
ErrCount+=compare(recBuf,cmp,6);
printbuf(recBuf,6);
clearBuf(recBuf,6);
printf("Slave: Messages received:%d Error:%d\r\n",mosi,ErrCount);
while(1);
And this is the master Code:
master.cpp
#define DURATION 5
Timer t;
SPI master(PB_5, PB_4, PB_3); // mosi, miso, sclk, ssel
DigitalOut cs(PA_4);
DigitalIn GpioEn(PA_7);
DigitalOut TestStart(PA_6,0);
void senddata(char *buffer,int size)
for(int i=0;i<size;i++){
master.write(buffer[i]);
void send_rec_data(char *sendbuf,char *recbuf, int size)
recbuf[i]= master.write(sendbuf[i]);
return 1;
return 0;
printf("\r\n");
char sendBuf[7]="Master";
char cmp [7]= "Slave!";
unsigned int mosi =0;
unsigned int error =0;
master.format(8,0);
master.frequency(1000);
wait(2);
master.write('a');
cs=1;
t.start();
TestStart=1;
while(t.read()<DURATION)
if(GpioEn.read()==0)
cs=0;
send_rec_data(sendBuf,recBuf,6);
mosi++;
cs=1;
error+=compare(recBuf,cmp,6);
printbuf(recBuf,6);
clearBuf(recBuf,6);
t.stop();
TestStart=0;
printf("Master Data: Time: %f seconds Mesages Transmittet:%d Error:%d\r\n", t.read(),mosi,error);
while(1);
The normal communication should be like this:
In the beginning it sends Master: Master
Slave: Slave!
After about 30-60 transmitted messages this error occurs:
after this the the communication is Master: Master Slave: !Slave
How can i solve the error that the slave is sending the bytes in the wrong order? Thank u Adrian
I think you have a misunderstanding on how SPI slaves work.
Since the slave data is sent out while the master data is coming in you need to pre-load the reply.
When you say slave.reply('a') you aren't telling it to immediately sent a reply of 'a' to the byte just received. You are telling it that as the next byte is received it should send a reply of 'a'.
So with your current code 'S' should be sent as the 'a' arrives, 'l' at the same time as 's' etc...
