6 years, 12 months ago.
How to use a timer as a wait function?
Im trying to write a code in MBED on my nucleo where a certain action has to be done for 1 second, and then it has to go back to the 'vooruit' case. i can't use a wait function because that will stop my entire code from working, so i have to use a timer or something else. In the picture u can see my current code which doesn't work. All i need is that once the "1" case starts, that the LED goes out for one second using a timer and then it switches back to the case above. Can anyone help me?
It's hard to tell without seeing your code but probably all you need is something like this:
Timeout LEDTimer;
void turnOff(void) {
led = 0;
// turns the LED on for the time given.
void turnOnForTime(float time) {
led = 1;
LEDTimer.attach(&turnOff,time);
Can you add your code (use the 'editing tips' to see how).
Try a Ticker first, see here:
https://os.mbed.com/docs/mbed-os/v5.11/apis/ticker.html
posted by Paul Staron 09 Apr 2019
