7 years ago.
Issue with LPC1768 --> Only 14Ko of memory ??
Hi !
That's my first time with the LPC1768 and I'm afraid to see the only 14Ko of memory ?? So I can't use nothing with that's..
Did you know the issue ?
PS : For the moment I just tested with a Mac. Maybe tormorow with a Linux pc..
7 years ago.
First of all check/update the firmware, see here;
https://os.mbed.com/handbook/Firmware-LPC1768-LPC11U24
Thanks but I can't copy/paste the firmware because I have just 14Ko of space in the Chip.. (512k in normal case) and the new firmware is 133ko :/
posted by Daniel M 21 Mar 2019
The MCU has 512K but the interface has 2MB available, it's the interface memory where you drop the .if firmware file. When you cycle the power (USB) the firmware is then updated.
If you mount the mbed on your MAC and check properties does it show any files? if so delete everything you can see and cycle the power. With no other files only mbed.htm you should see 1.98MB. As you say if you can connect on a Windows PC try the same and drop in the firmware file if you have the normal amount of memory showing. You may find then it mounts on the MAC as it should.
posted by Paul Staron 22 Mar 2019
okay but I canot push the new firmware.. 'out of memory space' only 14Ko :/ I tried with a Linux OS, same issue..
posted by Daniel M 23 Mar 2019
