7 years, 1 month ago.
How to import an mbed program from Mbed Online Compiler?
Hello, I'm trying to import a program from Mbed Online Compiler. As written in the guide I downloaded it as zip file and I pasted it in the Workspace folder. Then in Mbed Studio Beta I tried to make it as Active Program but the result is the following message: " Cannot set 'ProgramPath' as Active Program. Not an Mbed Program ".
I think that the idea of a Desktop IDE is very useful and nice idea. Can someone help me please?
Best regards Davide
Hi Davide, when a zip file gets exported, there are two layers of folders. If you move only the lowest level one into your workspace (e.g. the folder that directly contains the source), then that should work.
Let me know if that helps?
Thanks, Joe
Hi Davide, you probably tried to use program with mbed 2 library. I had same issue ("Cannot set 'Program Path' as Active Program. Not an Mbed Program") when I tried that. The program must be with MbedOS 5.
So the new tool cannot be used without an RTOS (bare metal) or with ver. 2 RTOS at all? Are there any plans to support that?
posted by 01 Mar 2019Here is the answer for your question https://os.mbed.com/questions/84891/Mbed-Studio-and-Mbed-OS-2/
posted by 01 Mar 2019Hi Jan, thanks for your answer. I think the one that you told me should be the problem. But on the Mbed Online Compiler how I can choose to use MbedOS 5? I simply created a new program without choosing the MbedOS. Is there a way to convert my program to MbedOS 5?
Thanks again Best Regards
posted by 04 Mar 2019Hi again, you can simple replace the library in the project folder in the online compiler. Delete your current mbed library from your project folder and the best way is to use - right click on the project folder and select "import library... >> from URL..." and use https://github.com/ARMmbed/mbed-os.
Best regards J.
