7 years ago.
Sending String via Serial
I would like to send a string through my serial communication. However I can't find any documentation on "puts" function and I don't know if I'm using it right. I connected my Mbed to an Arduino and its seems like Arduino doesn't receive the string.
Here is my code. When I press 6 or 9 it should send the correct String.
Mbed String code
Serial pc(USBTX, USBRX); // TX, RX
Serial TXRX(p13, p14); //TX, RX
char* s;
int main(){
pc.baud(9600);
TXRX.baud(9600);
while(1){
if(pc.readable()){
char x = pc.getc();
wait_ms(100);
if(x=='9'){pc.printf("%c\n",x);s="1,2,3";}
if(x=='6'){pc.printf("%c\n",x);s="7,8,9";}
pc.printf("%s\n",s);
TXRX.puts(s); //may be the problem
When I send a single char via "putc", my Arduino receives it well. So I assume "puts" is the problem.
Mbed single char code
int main(){
pc.baud(9600);
TXRX.baud(9600);
while(1){
if(pc.readable()){
char x=pc.getc();
wait_ms(100);
TXRX.putc(x);
This one is working.
And here is my Arduino code.
Arduino code
#include <Wire.h>
#include <Zumo32U4.h>
String TrameValeurs;
void setup() {
Serial.begin(9600);
void loop() {
TrameValeurs = Serial.readString();
//Serial.read(&TrameValeurs, sizeof(TrameValeurs));
Serial.print("String :\n");
Serial.print(TrameValeurs);
Serial.print("\n");
int virg1, virg2, virg3;
String inst1, inst2, inst3;
virg1 = TrameValeurs.indexOf(',');
inst1 = TrameValeurs.substring(0, virg1);
virg2 = TrameValeurs.indexOf(',', virg1 + 1);
inst2 = TrameValeurs.substring(virg1 + 1, virg2);
virg3 = TrameValeurs.indexOf(',', virg2 +1);
inst3 = TrameValeurs.substring(virg2 + 1, virg3);
Serial.print("instructions : \n");
Serial.print(inst1);
Serial.print(",");
Serial.print(inst2);
Serial.print(",");
Serial.print(inst3);
Serial.print("\n");
if((inst1=="7")&&(inst2=="8")&&(inst3=="9")){
//Serial.write(10);
ledRed(0);
ledYellow(1);
ledGreen(0);
if((inst1=="1")&&(inst2=="2")&&(inst3=="3")){
//Serial.write(20);
ledRed(1);
ledYellow(0);
ledGreen(1);
else{
ledRed(0);
ledYellow(0);
ledGreen(0);
Thank you
7 years ago.
I think your problem is s="1,2,3", that line is setting a pointer to a constant value not setting a pointer to point at a constant string. At no point is any memory allocated to hold the text.
Try the following changes
//char *s; char s[16]; //s="1,2,3"; sprintf(s,"1,2,3");
7 years ago.
You could try:
snip
char container[50]; //give 50 character size to be safe
sprintf(container,"%s",s);
TXRX.puts(container);
// or something different like-
int len;
len=strlen(s);
while(len--)
TRX.putc(*s++);
But I haven't tested this.
7 years ago.
Hi, you can use variable of the string type.
you can try..
#include <string>
Serial pc(USBTX,USBRX);
string testString;
testString = "Hello";
while (1) {
pc.printf("printf: %s\n", testString.c_str());
wait(1);
//or
pc.puts(("putc:" + testString + "\n").c_str());
wait(1);
So,
I tried all of your methods above but It still doesn't receive anything
From the Arduino, could "TrameValeurs = Serial.readString();" be the problem ?
posted by equalizer equalizer 01 Mar 2019Ok guys I found my problem,
I am really dumb cause on my Arduino I was reading a string coming from my pc and not from my Mbed by using Serial instead of Serial1. Thank you all :)
Edit : String is correctly sent
