7 years, 2 months ago.
Read file via SPI
I'm working with a Cortex-M7 and I need some external storage to be able to load some data at run-time. My idea is to use a microSD card connected to the Cortex via SPI (I'm using a Nucleo-144 board). I'm not very experienced in the SPI world but I believe what I'm trying to do should be doable. I have a few questions regarding this:
- What's the most convenient way to store the data in the micoSD card so it can be easily read via SPI?
- I'm aware of the doc and example here, but I was wondering if anyone could share a more complete example of how to read data from a file via SPI. (or point me to one)
- Is SPI the wrong way of doing this? (I'd like to perform this reading using a little memory and latency as possible)
Thanks!
Javier
Hi Javier,
I use FATFileSystem together with SDBlockDevice in my K64F. See the example at the bottom of:
https://os.mbed.com/docs/mbed-os/v5.11/apis/fatfilesystem.html
If you want to use the on board SD Flash with other devices (i.e. readable from a PC), do not use the LittleFileSystem. You also don't need SPIFBlockDevice or HeapBlockDevice.
Both of the items up top are embedded in the mbed-os library. You just need to "include" them in your code.
...kevin
Hi Kevin, thanks for your reply.
I've gone through the documentation and example here but can't make it work. I only get "Hardfault" messages when trying to run it on my NUCLEO-F767ZI. I'm following the same pin connection setup as in the sd-driver example (I know now it's deprecated). I'm wondering if you have a full working example of some minimal file read/write to an sd card. Thanks!
posted by 15 Jan 2019Sorry Javier, I was assuming you were using a K64F. ST does non-standard things sometimes. I have a DISCO-L475VG-IOT01A. They have a custom QSPIFBlockDevice driver that I had to use instead of SDBlockDevice. I had to do some digging in order to get things working. ST is slow to answer questions. At least now QSPIFBlockDevice is part of mbed-os.
This board also has a lot of I2C devices AND they don't use the standard mbed I2C driver either.
posted by 15 Jan 2019No worries. I managed to make it work. This is what I did:
- 1. Clone mbed-os-example-filesystem repo.
- 2. Checkout branch "override-storage-components"
- 3. Replace the SPIFBlockDevice bd(...) line with a SDBlockDevice declaration.
- 4. (optional) replace `LittleFileSystem` with `FATFileSystem` if you want to read/write data to SD card and make it visible from your PC.
- 5. Connect PINS as shown in this repo. You don't need that precise SD-card shield. Most SD-card shields will work.
- 6. Compile it with `mbed compile -m auto -t GCC_ARM -c -f`. Once it's flashed use `mbed sterm` to see the logs.
Hope this is helpful for someone. Because of rules in this forum, I can't post an answer to my own question, so please feel free to post one with the steps above.
posted by 16 Jan 2019
I managed to solve this. These are the steps I followed:
posted by javier fernandez 18 Jan 2019
