7 years, 2 months ago.
OS version & export to desktop IDE error
How do I know which version of OS Im using OS 2 or OS 5 There is no indication of version on compiler page. Also while I select an example from Boards section & try to Export to desktop IDE KEIL , it ends up in page error.
if you are using the library "mbed-os" then is mbed 5, otherwise if its just "mbed" its mbed 2
You could also use version control or mbed_version header file to check the version
posted by Martin Kojtal 07 Jan 2019
