7 years, 4 months ago.
Nucleo L476RG with MTi 1-s development kit - pin map not found
I am trying to establish UART communication between Nucleo L476RG microcontroller and MTi 1-s development kit. I was following https://os.mbed.com/teams/Xsens/code/MTi-1_example/ as guideline how to connect both of them. The pins seem to match as described in that post, however I have not managed to establish any data transmission as every time I use to connect it, i receive that "pinmap-not-found-for-peripheral". For the pin map I was following the https://www.xsens.com/download/pdf/documentation/mti-1/mti-1-series_dk_user_manual.pdf and https://os.mbed.com/platforms/ST-Nucleo-L476RG/ and what i came up with:
- if defined(TARGET_NUCLEO_L476RG)
- define PC_TX PA_2
- define PC_RX PA_3
- define MT_TX PA_3
- define MT_RX PA_2
- define MT_SDA PB_9
- define MT_SCL PB_8
- define MT_ADD0 PA_5
- define MT_ADD1 PA_6
- define MT_ADD2 PA_7
- define MT_MOSI PA_7
- define MT_MISO PA_6
- define MT_SCLK PA_5
- define MT_nCS PB_6
- define MT_NRESET PB_5
- define MT_DRDY PB_3
Which correspond to the given links above. Do you have an idea what could be wrong?
Thank you.
