7 years, 11 months ago.
Runtime error when combine EthernetInterface and SD-Driver
I can write file to SD-CARD with SD-Driver only. It's work. I can receive IP Address from DHCP with EthernetInterface only. It's work. but when I combine 2 code, I have error on runtime.
RESULT:
I can receive IP Address from DHCP normally,
but I have an error from SD-Driver "Failure 5"
MY CODE
#include "FATFileSystem.h"
#include "SDBlockDevice.h"
#include <errno.h>
EthernetInterface net;
SDBlockDevice sd1(MBED_CONF_APP_SPI_MOSI, MBED_CONF_APP_SPI_MISO, MBED_CONF_APP_SPI_CLK,
MBED_CONF_APP_SPI_CS);
void return_error(int ret_val){
if (ret_val)
printf("Failure. %d\r\n", ret_val);
else
printf("done.\r\n");
void errno_error(void* ret_val){
if (ret_val == NULL)
printf(" Failure. %d \r\n", errno);
else
printf(" done.\r\n");
net.connect();
FATFileSystem fs1("sd1", &sd1);
printf("Welcome to the filesystem example.\r\n");
printf("Opening a new file, stampvalue.txt.");
FILE* fd1;
fd1 = fopen("/sd1/stampvalue.txt", "w+");
errno_error(fd1);
for (int i = 0; i < 20; i++){
printf("Writing decimal stampvalue to a file (%d/20)\r", i);
fprintf(fd1, "%d\n", i);
printf("Writing decimal stampvalue to a file (20/20) done.\r\n");
printf("Closing file.\r\n");
fclose(fd1);
net.disconnect();
while(1) { }
NOTE: I use Nucleo F746ZG board, MbedOS-5, SD-Driver from https://github.com/ARMmbed/sd-driver/
Sorry for english language.
This is a known issue and it is due to a conflict between SPI and Ethernet pins on Nucleo_144 boards.
See here for more information: https://os.mbed.com/teams/ST/wiki/Nucleo-144pins-ethernet-spi-conflict
Regards
