8 years, 1 month ago.
Link of the available pins and peripherals outdated (B-L072Z-LRWAN1)
I'm trying to get some kind of access to the GPIO on my B-L072Z-LRWAN1 but i've been stuck so far...
I've tried to set up the GPIO but i'm unable to get any kind of access to any of the pins.. I'm only able to transmit hardcoded values which pains me a lot.
I was hoping to find some useful information with a more detailed pinout map but the links are broken, does anyone have any kind of idea or the link to the actual map?
Thanks a lot!
Maxime DEWASMES
Hi Maxime
Pin overview is available in the platform MBED page : https://os.mbed.com/platforms/ST-Discovery-LRWAN1/
Can you explicit the uncorrect pins ?
Can you copy/paste some code part ?
Jerome
Hi Jerome
I know this page, i was posting my question from there, but i was pointing out that the links to "PeripheralPins.c" and "PinNames.h" was broken.
Back then i was un-sure I was using the correct code to initialize the correct pins, so I hoped to find the right pin cast in these documents, however i was able to fix that at the start of the week, just forgot to close this issue!
Thank you for the reply though, it appears the main problem is that I was a bit dumb when I initialised the GPIO in my code... I can now use pins to get some voltage level via the ADC!
Sorry to have taken up some of your time,
Have a nice day,
Maxime
posted by 23 Mar 20188 years, 1 month ago.
Hi Maxime,
I found the following user manual on ST's website, it looks like page 18 has a detailed list of the pin names and their functions: http://www.st.com/resource/en/user_manual/dm00329995.pdf
- Jenny, team Mbed
