8 years, 1 month ago.
mbed LPC1678
Anyone tested this board on LPC1768?
Assuming you make the appropriate connections there is no reason why it wouldn't work, joining that shield on to the mbed LPC1678 would effectively give you this: https://os.mbed.com/platforms/u-blox-C027/
However the mbed LPC1678 board isn't arduino form factor so that ublox board won't connect to it directly. It could be made to work but it would make your life a lot simpler if you were to use an mbed board with compatible connectors.
