10 years, 11 months ago.
Array and binary elements
How can I store a binary number in an array i.e. the array element is either a 1 or a 0. Appreciate any help
You can either use an array of type bool or use an array of chars and use values of 0 or 1. Either way you will use up 1 byte per array entry.
If you want to store 8 bits per byte then you need to create your own code that uses binary masks to pack the data.
may be by using bitset c++. search for C++ bitset on the web. It's very usefull to manipulate bit strcutures
http://www.cplusplus.com/reference/bitset/bitset/bitset/
posted by Raph Francois 06 May 2015
