10 years, 10 months ago.
Compiler producing different or corrupt hex files from the same code
I am running into lots of compiler issues in the last 24 hours. Hey files are not full size (a file that is usually 134K is downloading as 84K). The file obviously does not work properly. Also, if I re-compile the hex file (without changing any code at all) the hex files produced are similar but significantly different. I can duplicate this by selecting the nrf51822FOTA, compile, then select nrf51822, compile, and then select nrf51822FOTA, compile. Very different hex files with identical code. This is very disturbing! Usually after a few hours the online compiler starts to produce the proper sized files again.
Same here with nRF51822. Have been having this issue for a day now. Also libraries display as "Documentation not ready" ...
Sounds like it's system wide - another thread
https://developer.mbed.org/questions/7996/Compiler-messed-up/
posted by Kevin Braun 01 May 2015
