8 years, 3 months ago.  This question has been closed. Reason: Spam/Innapropriate
why do I get crazy readings?
I have imported the library and code and modified it to suite a FRDM-KL25Z. I am printing results on TeraTerm. I have two problems. 1.)on reseting th device manually, my readings may be as extreme as 280+C and -500+% rel. hum. Sometimes they correct to more a acceptable readings but not always. 2.) Once the devices have settled on a reasonable read out (ussually 3 to 4 iterations of the while loop) they remain unchanged regardless of the changes in the environment(even after as long as 10 mins)
Is the sensor faulty???
Solved. Using wrong input pins! Sorry! Thanks for all suggestion. Illuminating regardless
posted by Samuel Spinn 07 Feb 2018
7 years, 4 months ago.
So it turns out I was using the wrong pins. I was using marked as the I2C1 pins but are also simultaneously PWM pins (pins PTE29 and PTE30). It seems because they are also PWM pins it wasn't always working properly? Also, from the pin-out, there are two other sets referred to as the I2C1 pins.
Switching to the I2C0 pins, readings stayed reasonable.
7 years, 6 months ago.
I am reading about FRDM-KL25Z before 2 3 days but I did not get any clue how it works what functions FRDM-KL25Z have. Anyone who have good knowledge about this I have read assignment writing on this topic but did not get any help from them I wanted to more about that.
7 years, 5 months ago.
Well, I do not have enough knowledge about it but I can recommend you Assignmentace writers at cheap who can definitely help you to get the desired solution easily because I have also some related issues and after getting guidance from I was able to do the solution. You can also contact here for some guidance it will be helpful for you.
Do you have placed pull-up resistors on SCL and SDA lines?
It is part of an assembly with a 10K Ohm resistor on the data line. https://learn.sparkfun.com/tutorials/sht15-humidity-and-temperature-sensor-hookup-guide?_ga=2.82199637.2120182754.1512337709-886845932.1508196254 No other resistors included.
posted by Samuel Spinn 03 Dec 2017
Regardless of that, I was awed with insane readings. It is as of now my own device of decision for a minimal effort, yet I positively would prefer not to speak to myself as any sort of expert on the topic order an assignment!
I attended Code Wars 2018, and it was amazing. Even though the event is not so large-scale, UK Assignment Writing Service does a pretty good job. By far has the best quizzes and surprise events. I personally participated in the Creative event (which the team did an amazing job in) and also made some good friends while attending this years event.
You will have to get such helpful tips from http://www.affordable-dissertation.co.uk/dissertation-writing-services-uk/ to pick up such crazy reading . if you feel the need of our help we remain at 24 hours online for sporting such as for you
posted by neil jakson 13 Dec 2018
