8 years, 6 months ago.
The board doesn't work with Nucleo F767ZI
I have just got the IDB05A1 board and I tried to run the example with the Nucleo but it didn't work. Then I tried updating the firmware for the IDB05A1 from https://os.mbed.com/teams/ST/code/BlueNRG-MS-Stack-Updater/ but it also didn't work. Can you check this problem? Thank you
Dear Duy tran,
please take a look at this thread. Your issue should be very similar and you'll find a solution to fix it.
