9 years, 1 month ago.
how to program the EFM32™ Leopard Gecko 32-bit Microcontroller
/media/uploads/santhoshkumar181994/leopard-gecko-starter-kit.jpg
Silicon Labs' EFM32™ Leopard Gecko ARM® Cortex®-M3 based 32-bit microcontrollers (MCUs) provide flash memory configurations up to 256 kB, 32 kB of RAM and CPU speeds up to 48 MHz. …
https://developer.mbed.org/platforms/EFM32-Leopard-Gecko/
You have already added this board to your compiler which is a required step. Start with the simple BLINKY LED code example -> compile -> drag & drop the compiled .BIN file to the drive letter linked to this Leopard Gecko board -> then press the RESET push button on your board to observe the results.
Does this answer your question ?
If not, what do you wish to do with this board ?
