9 years, 2 months ago.
STM32F429ZI DISCO BOARD NOT DETECTING
Sir I have STM32F429I DISCO BOARD. It is not detecting in the system. LCD display turned on white screen displayed. how will solve this problem.
The STM32F429 Discovery kit (STM32F429I-DISC1) allows users to easily develop applications with the STM32F429 high-performance MCUs with ARM®Cortex®-M4 core.
9 years, 1 month ago.
hello,
I have had the same problem. The demo supplied on the mbed website will not work. The LCD display is just white in colour I have installed the driver and upgraded the software on the board. Could you perhaps suggest something that I can do.
Do you see the disk drive on your PC ?
Can you try to update the STLink driver: https://developer.mbed.org/teams/ST/wiki/ST-Link-Driver
and then to update the board STLink fw: https://developer.mbed.org/teams/ST/wiki/Nucleo-Firmware
Sir we updated but no STLink not detecting on the PC. any chance to replace the board
posted by ARUN MOHAN 01 Feb 2017
hi, Could you please confirm if you are using a STM32F429-disco or a STM32F429-disc1?
The STLink on the first version does not support drag and drop / virtual com port. so it won't show-up as disk drive when you plug it.
stm32F429I-DISC1
posted by ARUN MOHAN 03 Feb 2017
Many times I tried to connect the board but On board stlink not detected. Two LED's are working when I connected the usb power, LD1 is flashing and LD2 continuous glowing. This is the current situation
I have a similar problem with Windows 10. https://developer.mbed.org/questions/76649/Nucleo-boards-do-not-work-with-Windows-1 What is your operating system?
posted by Mark Peter Vargha 03 Feb 2017
What I would try now:
  • try on another USB port - if the port you are using cannot provide enough current, the device won't start. (on a hub for example) You may want to detach all unnecessary USB devices that maybe consume your current budget.
  • try on another PC
  • try to
    remove the device,
    uninstall the driver,
    reboot,
    install the driver again,
    reboot,
    plug the device
  • make sure the upgrade finished correctly, eventually do the upgrade again...
posted by Maxime TEISSIER 06 Feb 2017
