9 years, 4 months ago.
JCU module errors
Is it possible to make JCU module tolerate reset marker errors as (libjpeg) does. For example libjpeg says "Corrupt JPEG data: 1 extraneous bytes before marker 0xd3" and even though the JPEG is successfully decoded and viewable. However if you try to decode the same image with the JCU it just exits with error "JPEG_CONV_JCU_ERR". Аs far as I read the hardware manual of the RZ/A1H there isn't such possibility and in this connection ... Does anyone knows a decent way for transcoding from MJPEG to JPEG so the JCU module do not complain. (The source MJPEG stream is from a Logitech C270 web cam. Should I try another brand ?)
I think that it can be realized by changing ErrorFilter with "R_JCU_SetErrorFilter()".
#include "JPEG_Converter.h"
#include "r_jcu_api.h"
JPEG_Converter decoder;
JPEG_Converter::bitmap_buff_info_t aBitmapData;
aBitmapData.width = SAMPLE_WIDTH;
aBitmapData.height = SAMPLE_HEIGHT;
aBitmapData.format = JPEG_Converter::WR_RD_YCbCr422;
aBitmapData.buffer_address = (void *)JCUBuffer_OUTPUT;
// Set Error Filter
R_JCU_SetErrorFilter(JCU_INT_ERROR_SEGMENT_TOTAL_DATA | JCU_INT_ERROR_MCU_BLOCK_DATA);
// JPEG_Converter
decoder.decode((void *)JCUBuffer_INPUT, &aBitmapData);
The recommended CMOS Micron economical camera is MT9V111 which is designed to work with GR-PEACH. And is available from digi-key with audio video shield. The GR-PEACH WebCamera application and QR barcode ZX application also uses this camera to read and convert 2d QR codes into text ASCII. Other video in is via Audio video NTSC shield board. Manual focus is available on MT9V111 camera module.
