9 years, 5 months ago.
Access mbed UID
As RZ-AH1 doesn't have device unique ID, i tried to access the mbed UID to generate mac address.
I have defined DEVICE_SEMIHOST to be able to use the method "mbed_interface_uid"
At execution, this method return "257" and array is not modified, this return value is not described in header files.
Is there any specific initialization to run before the call to "mbed_interface_uid" ?
I will hazard a guess and say you are an advanced mbed5.2 OS user so this may be your answer:
mbed https://developer.mbed.org/users/mbed.../mbed/.../mbed__interface_8h_source.html Aug 19, 2016 - ... interface mac address 00024 * if MBED_MAC_ADD_x are zero, interface uid sets mac address, 00025 * otherwise MAC_ADD_x are used. Uniquely Identify An Mbed? | mbed.
I am trying to use the "int mbed_interface_uid(char *uid)" method of the file you are pointing, but the return value doesn't match the header description. It return "257".
I am using e2studio 5.1 and a Segger Jlink debbuger to load binaries. I tried to disconnect the debugger and reset the board, i have the same return value.
Regarding the other answer by Daiki Kate, i suppose that the Mbed ship has to be the debugger in order to respond to semihost commands. Is there a procedure to set the mbed ship as debugger once binaries are flashed ?
posted by 27 Oct 20169 years, 5 months ago.
When using the Semihosting it must be connected to the debugger.
Please see below for more information.
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0376d/Bgbjjgij.html
If you connect to the global network, please set the correct MAC address.
Joffrey Coffineau, Which environment are you running in mbed5.2 OS or legacy mbed3.0
Search Results mbed | mbed https://developer.mbed.org/users/mbed.../mbed/.../mbed__interface_8h_source.html Aug 19, 2016 - ... interface mac address 00024 * if MBED_MAC_ADD_x are zero, interface uid sets mac address, 00025 * otherwise MAC_ADD_x are used. Uniquely Identify An Mbed? | mbed https://developer.mbed.org/forum/helloworld/topic/2048/ Nov 9, 2012 - 25 posts - 11 authors extern "C" mbed_mac_address(char *); int main() { uint64_t uid = 0; char ..... the MAC is extracted) using a semihost call to the mbed interface. Ethernet (MAC) address? 24 posts Jul 8, 2015 セミホスティングの無効化 6 posts Jun 26, 2014 mbed JTAG mechanism 12 posts Aug 25, 2011 More results from developer.mbed.org mbed_interface.h https://developer.mbed.org/users/mbed_official/code/mbed/file/.../mbed_interface.h ... Mbed interface mac address * if MBED_MAC_ADD_x are zero, interface uid ... int mbed_interface_connected(void); / Instruct the mbed interface to reset, ... Beta - Handbook | mbed https://developer.mbed.org/handbook/Beta Functions to control the mbed interface debug connection and power state: ... get the 6-byte unique mac address, that is part of the mbed interface UID. mbed_interface.h https://developer.mbed.org/users/screamer/code/mbed/file/.../mbed_interface.h Oct 24, 2012 - Functions to control the mbed interface * * mbed Microcontrollers have ... based on the interface UID * If the interface is not present, it returns a ... mbed-os/mbed_interface.h at master · ARMmbed/mbed-os · GitHub https://github.com/mbedmicro/mbed/blob/master/hal/api/mbed_interface.h
- include "device.h". /* Mbed interface mac address. * if MBED_MAC_ADD_x are zero, interface uid sets mac address,. * otherwise MAC_ADD_x are used. */.
mbed-drivers/mbed_interface.h Source File
https://docs.mbed.com/docs/mbed...api/.../drivers_2mbed__interface_8h_source.html
Apr 25, 2016 - 22 /* Mbed interface mac address. 23 * if MBED_MAC_ADD_x are zero, interface uid sets mac address,. 24 * otherwise MAC_ADD_x are used.
hal/api/mbed_interface.h Source File - mbed Documentation
https://docs.mbed.com/docs/mbedmicro-api/en/.../mbed__interface_8h_source.html
24 * if MBED_MAC_ADD_x are zero, interface uid sets mac address, ... 50 / Determine whether the mbed interface is connected, based on whether debug is ...
mbed_interface.h in Smoothie/gcc4mbed/external/mbed – Zi.iS
https://zi.is/p/browser/Smoothie/gcc4mbed/external/mbed/mbed_interface.h?rev...
4, * mbed Microcontrollers have a built-in interface to provide functionality ... 57, * This returns a string containing the 32-character UID of the mbed interface.
mbed-ls 1.2.4 : Python Package Index
https://pypi.python.org/pypi/mbed-ls/1.2.4
Python
Oct 3, 2016 - mbed-ls is a Python module that detects and lists mbed-enabled devices ... mbed-enabled device with host computer using USB interface.
posted by XtrmDesignsLLC GRPeach 27 Oct 2016
