9 years, 5 months ago.
Terminal Window blank while using serial window
nothing is displayed while using serial communication in terminal window. i have tried with putty and teraterm
Typically the terminal setup is 115200 baud - some systems defaults are 9600- also which connector are you using - try using both USB micro to PC. Which application are you using as some do no sent text to the "dumb" terminal ?
xtrm designs llc
