9 years, 7 months ago.
Problem to send SMS using SARA G350
I am trying to connect via GSM with SARA G350 using C027_Support_Test example. The board recognize the SIM but the connection is denied with CSD registration denied. Does anyone know why this problem is happening? I have already tried with a prepaid and with a non prepaid SIM card and both got the same message.
Hi Igor,
might be a problem with network operator settings, maybe signal strength..
You should consider issuing AT commands manually, to set the module in a correct way and successfully register with your SIM.
Feel free to contact me via private message, I can guide you through some checks you can do in case you don't know how to proceed.
I hope this helps, Jaka
In addition: CSD stands for circuit switched data, so, make sure that this service is available for your sim/network operator - allowed services and CSD settings. As I explained try issuing AT commands to MDM manually to see where is the problem (use MDM transparent serial example)
Regards, Jaka
posted by 01 Sep 2016
