9 years, 8 months ago.
Can we run an operating system on GR-PEACH? If Yes, Will BSP & technical support be provided ?
I would like to port embedded linux or any other OS , on which I should be able to run opensource softwares such as OpenCV . Thanks .
GR-PEACH is an Mbed enabled platform which combines the advantages of the Mbed ecosystem and Arduino UNO form factor.
9 years, 3 months ago.
The Renesas RZA1H can run XIP Linux OS. This is running the Linux kernel from Serial Flash. See this link for information http://renesasrulz.com/renesas_forum_home/rz/m/mediagallery/
The GR-PEACH has limited amount of Serial Flash (8MB) and no SDRAM( not needed for XIP Linux).
There is a unique GR-PEACH/RZA-H/M/L RAM and Flash configuration so it depends on the size your binary image of OS and applications. The Current GR-PEACH uses the 10MB RAM on Chip with NO external DDR RAM or options. This will be the memory boundary for your OS/OpenCV/application. There are other Renesas platforms that are used with Linux, OpenCV and BDTi Optical Flows.
I dont think the GR-PEACH can hold an OS. My project also needs opencv, I found a mbed-opencv program :
https://developer.mbed.org/users/joeverbout/code/main/
I combiled it, showing much errors. also I found a project on opencv :
https://developer.mbed.org/teams/Micon-Car-Rally-with-Renesas/code/
Check this, share me ur findings, I also struggling.
